Need info on a D-15 or D-17
Plow Man
07-07-2002 17:03:01
I was thinking of buying one of these kinds of tractors. I was wondering, does both of these tractors have live pto when the main clutch is disengaged? Or is it like a WD or WD45 were there is a seperate clutch to run the pto and hydraulic pump? I also read something about a "power director", what is that? I read in a book that this can give the tractors eight foward speeds, and two reverse. Is that so? Also what is the easiest to find a D-15 or D-17? What do some of these cost? I would like to someday get one with a wide front, and a diesel motor, with power steering, and 3pt. I was looking at one for a shredding tractor. Is one of these tractors good for shredding? I run a 6' bushhog, would a D-15 handle that size in 2 to 3' tall grass, or would I be lugging the engine? Any info would be great! Thanks.
JMS/MN
07-07-2002 19:31:29
 Re: Need info on a D-15 or D-17 in reply to Plow Man, 07-07-2002 17:03:01
The D series was an improvement over the WD45 with more hp, and with the power director, you get a low and high range in each of the speeds, forward and reverse, while maintaining the live pto/hudraulics of the WD. D17s are more popular, but I would stay away from the diesel version- too many problems with bad heads, and for the casual user, the gas is plenty adequate. Cost is likely $2000-4000 for a D17, depending on series (age). 15 is smaller and not a whole lot different in price. Most you'll find have wide front and snap-coupler, not 3pt hitch, but adapters can be purchased. Perhaps you can find a Series Four with factory 3pt.
