Half choked allis C
Gary
07-05-2002 20:01:02
Ihave an allis C,it runs with choke halfway on,floods if all the way on, if i shut the choke off it dies.cleaned carb,blew out all passages,sediment bowl ,gas flows very freely out of the line next to carb,changed float level still the same.with choke half on you can rev up fast idle down still runs till you shut off choke,seems to get worse was only doing this under load it would cough.everything clean,checked for leaks around manifold,getting stumped.any suggestions would really be appreciated thankyou
potter
07-07-2002 13:57:04
 Re: half choked allis C in reply to Gary, 07-05-2002 20:01:02
I had that same trouble years ago, drove me nuts for two weeks. Finally found I had mixed some diesel into the gas by accident!! fresh gas and ran fine. Make sure yours in fresh. sounds too easy but it could be..
Duey (IA)
07-06-2002 06:46:42
Gary,
I have this from my stash of info Duey;
Bryan Smith Posted 05-28-2002 at 06:26:55 [Reply] [Send Email] ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- --
OK, my 1949 AC B with a Zenith carb hasn't run right since I bought it. It runs fine from 1/2 throttle up (notch 6 and above) but under that I had to keep the choke out to keep it running - and the air screw was all the way in, too. Backing it out resulted in loading up with fuel.
So I pulled the carb apart, cleaned it, adjusted the float setting (it was too high), and added an inline filter. Put it back together and the same problem, but now I could back the air screw out almost 1/2 turn .... argh! Aggravating since I have a 1950 B with an MS carb that runs like a sewing machine.
Last week I was talking with the guy I bought the 1950 B from (he's *big* into John Deere L and LA tractors). He asked if the venturi was loose - why yes, it is. He then told me that if it's loose it will actuall rotate around in the carb while the engine's running and do all sorts of weird things.
The fix - take the carb apart, remove the gasket and set the two halves of the carb back together. If the body and top fit flush then the venturi's too loose. Make a *thin* washer and fit it around the venturi so there's a small crack between the body and top of the carb when it's put together without the gasket.
When I got home I checked and sure 'nuff, the carb body and top fit together flush without the gasket in place. So, I got a piece of 18 gauge aluminum electric fence wire, made a cirle, and beat it flat with a hammer - probably 0.010 or maybe 0.015 inches thick (a guess on my part). I fit this washer around the venturi just above the 4 flanges on the bottom so the washer would be between the venturi flanges and the top part of the carb when the venturi was installed.
