Magneto or distributer?
Jc
07-05-2002 12:14:50
I have a 1958 d-17. I am curious. I think i read somewere that if you have a coil then you don't have a magneto. Is that true?
THanks
John
JMS/MN
07-05-2002 22:38:59
 Re: Magneto or distributer? in reply to Jc, 07-05-2002 12:14:50
Yup- all D17s came with a distributor/coil (battery) ignition- just like WD45s. Magnetos were on earlier AC models. CA typically had bettery ignition, although I think first ones might be mags. All distributors need coils. Magnetos make their own spark and do not need coils or batteries.
Bryan Smith
07-05-2002 12:26:48
Yep. The magneto has an internal coil. If you have an external coil it's either a distributor ignition system (also battery ignition) or a magneto system that had a faulty coil and has been re-wired to be a distributor system. AC made the switch from magnetos in 1953 (from memory, but that should be close) so any tractor made after 1953 should have a distributor.
