Wc 45 trans shifter
m. flowers
07-04-2002 14:42:28
my father in law took shifter with shift forks off to fix. he couldn't. sent to unknown shop to get fixed.didn't tell me where! he passes on! need shifter for ac45! great tractor but my problem is obvious! thanks for any help!
JMS/MN
07-08-2002 22:25:36
 Re: wc 45 trans shifter in reply to m. flowers, 07-04-2002 14:42:28
Check with salvage yards for a replacement shifter tower and forks, and lever. You need the curved shifter lever for a WD45. A WD tower works if you drill out the hole for the second pin that guides the shifter, but the shift lever still needs to be curved. (WD tower: run the drill bit through the existing hole, through to the other side, same size as existing hole)
