WD Hydraulic leak
Greg
07-01-2002 17:10:00
Is it possible for the hydraulic fluid in a WD to get into the transmission? What's the fix?
Richardh
07-03-2002 06:07:59
 Re: WD Hydraulic leak in reply to Greg, 07-01-2002 17:10:00
Yes it is pos. their is no seal btween then their is the shaft that yr PTO gear runs on. that shaft is a tight fit but will let a little by only if yr trans. is low enought 4 grav, flow. I have had mine apart. Only other way is if u got a crack btween the 2 houseings. R u shour that it is leading in2 the tran. and not out the rams?
Richard (KS)
07-02-2002 11:52:29
Don't have the service manual in front of me but I think there's a seal that separates the hydraulic and transmission compartments, this could be the problem.
