WD Serial # HELP!
Rob Bush
07-01-2002 12:46:32
This is an odd question. I just picked up an Allis WD. I've always checked the year by the number on the left side of the block. The number on this tractor says WD-290402-PA. From the books I've checked, the numbers don't go that high. The WD-45 doesn't even go that high. Is this the wrong number to be looking up? What year is it? Why is the number so high? Also, just curious, what does the "PA" stand for? Thanks Alot!
-Rob Bush
Richardh
07-01-2002 13:13:37
 Re: WD Serial # HELP! in reply to Rob Bush, 07-01-2002 12:46:32
Serial# is on the back of the rearend around the spring whole an the plate, if not on it it will b under the brade plate. The # u gave is yr moter # as 4 the PA have no idea
Rob Bush
07-01-2002 15:41:00
 Re: Re: WD Serial # HELP! in reply to Richardh, 07-01-2002 13:13:37
Thanks Richard! Found the right number on the rear end(#82987=1951) makes alot more sense! Thanks again,
-Rob
