Re: WD vs. WD-45
oldtimer
06-30-2002 18:11:04
the late WD's were all the same as the WD45 except for the crankshaft. the wd had a 4in stroke, the wd45 had a 4.5 in stroke get it???45----4.5. put a 4.5 crank in a late model wd and you have a WD45.
Tom
06-30-2002 18:33:29
 Re: Re: WD vs. WD-45 in reply to oldtimer, 06-30-2002 18:11:04
Yes, but you need the power crater pistons too.
willie
07-07-2002 15:40:56
 Re: Re: Re: WD vs. WD-45 in reply to Tom, 06-30-2002 18:33:29
wd had 201 cu in displacement 4 in bore & stroke, wd45 had longer stroke to get approx 225 cu in. also last 6 months or so of wd & wd45 had constant mesh trans( the one with the curved shifter) earlier wd had sliding spur trans(straight up shifter) wd had a drop pin under trans to attach plow etc, wd45 had snap coupler, latched by itself when backing into plow. otherwise very little difference
