PTO Shifter O-ring seal
Doug
06-27-2002 20:49:33
I think I have found the source of a leak on my D14 and am wondering if anyone can tell me if I have to split the tractor to fix it. It appears that the O-ring on the PTO shift lever is the source of my leak. The previous owner welded an extension on the handle, probably distroyed the O-ring. Can I replace this O-ring without splitting the tractor by going through one of the access ports on the torque tube or due I have to split the tractor. Any help would be appreciated.
Thanks,
Doug
Trent Williams
06-27-2002 21:00:21
 Re: PTO Shifter O-ring seal in reply to Doug, 06-27-2002 20:49:33
Sorry, You have to split it. It's not too bad, just be Safe. Use good rigging/supports. Trent
Dave
06-28-2002 14:04:06
 Re: Re: PTO Shifter O-ring seal in reply to Trent Williams, 06-27-2002 21:00:21
I've got leaks at both the Pto lever and the power director lever. I think my O'rings have gone square with age. It's a narrow front and I'm frankly afraid to try splitting it. If it gets away from me I'm in trouble.
