Slop in a narrow front end
John
06-27-2002 16:29:20
Has anyone tried to get rid of the slop in a narrow front end? If so were did you find out the slop was coming from. What parts did you replace?
I purchased a parts catalog and in it it shows a blue print of the front end. It looks to me that the slop would be in the splined colar that connects the pedestal to the front end. this sound about right? Any comments would be appreciated.
thanks
John
JMS/MN
06-27-2002 23:01:09
 Re: Slop in a narrow front end in reply to John, 06-27-2002 16:29:20
You did not mention which tractor- but I had a similar problem on a WD- The tapered roller bearing at the bottom of the pedestal was worn (scalloped) which allowed the front end to wobble a bit on gravel, and constantly on a blacktop road.
John
06-28-2002 02:50:21
 Re: Re: Slop in a narrow front end in reply to JMS/MN, 06-27-2002 23:01:09
Was that an easy fix? My tractor is a d-17
JMS/MN
06-28-2002 22:50:59
 Re: Re: Re: Slop in a narrow front end in reply to John, 06-28-2002 02:50:21
Yes, it was an easy fix- if the bearing is scalloped, replace it. Other sources of wear are the large gears, but the bearings are likely to go first.
