Modified AC tractor
mike
06-26-2002 18:27:13
I have found what appears to be an AC WD45. It was modified by tractomatic manufacturing. It has a heavy duty endloader on what used to be the rear of the tractor. model#- TRW, Serial#- 91. Serial # plate is on the modified part of tractor. I believe it was manufactured in Deerfield Illinos. Have a chance to buy for $1800.00. Does anyone know anything about?
-thanks-
Mike
Tom
06-27-2002 18:52:10
 Re: modified AC tractor in reply to mike, 06-26-2002 18:27:13
It may have 4 speeds in "reverse" if the seat is facing the "back" of the tractor. This can be done and changed by placing the ring gear on the other side of the pinion inside the diferential. Not a small job but it would be possible to make it into a 4 speeds forward tractor if that is what you want.
