Re: WD or WD45?
Tom
06-24-2002 17:40:13
Later WDs had the curved shift lever that was used on the newer constant mesh transmission. As was said, the bolted on side cover on the right side of the engine tells the story on the engine. Thee was no 45 engines with this. It could be a 45 with a WD or WC engine though, except for the fact that the transmission is the older sliding gear type with the straight shift lever. Another way to tell a 45 at a glance is they had a curved seat support as opposed to one with two different straight sections with a bend between them. Again, this could have been changed over the years too.
