CA hand clutch adj.
Tommy Carpenter
06-23-2002 17:03:26
Could someone tell me how to adjust the hand clutch on the CA Allis Chamlers? I just got this tractor. It is supposed to be a '55 with the snap coupler hitch (has an adaptor for 3pt.). It is in great shape and has new paint and decals. However, the hand clutch will not completely stop the tractor (it is still trying to pull). How do you adjust the hand clutch?
Thanks,
Tommy
Mike (Oh)
06-24-2002 10:38:23
 Re: CA hand clutch adj. in reply to Tommy Carpenter, 06-23-2002 17:03:26
Hi, just tried to adjust mine because it was doing the opposite � slipping while trying to plow. Behind the hand clutch lever is a bolt that locks into a cog wheel. Loosen the bolt and with a screwdriver move the wheel counter clockwise (looking at it from right side of tractor) to loosen the clutch. Mine moved easily by just sticking the end of the screwdriver into the teeth of the wheel and prying it a tooth at a time.
