WD45 Water pump/fan pulley alignment
Steve Slaughter
06-22-2002 17:27:52
I've replaced the motor in my 1948 W Speed Patrol with an engine from a WD45. The old water pump transferred to the new motor and bolted up fine, but the pulley doesn't seem to be aligned properly with the belt pulley on the crankshaft and the generator pulley. Looks like it's about 3/4" to the rear. The fan pulley has an adjustment, but only makes the pulley wider. I thought I might have to buy a water pump just for a WD45, but they list the same pump for WC, WD, and WD45. I can make a spacer for inserting between the block & pump. Can anyone help with a suggestion?
