WD lube types
Richard Craig
06-22-2002 16:47:00
Any of you all know what types of oils are needed for the WD engine, transmission, and hydraulics? I'm also looking for a source for new WD decals.
Tom
06-24-2002 17:48:43
 Re: WD lube types in reply to Richard Craig, 06-22-2002 16:47:00
You can use regular multi weight engine oil for the engine. Hydraulic oil or "tractor lube" for the hydraulics. Transmission and rear end (same gear box) takes 90 weight gear oil. There are 3 drain plugs and two filler plugs, use them all for a complete job. Don't forget the final drives too, you have to take off the pans to drain them, them fill to plug level with 90 weight gear oil.
