C mounted plow manual
Stevie
06-21-2002 23:46:44
Hello. My dad has a 1947 C and is in need of a manual on how to bolt on the mounted plow. Any help on this matter will be greatly appreciated. THANKS.
Butch (OH)
06-22-2002 03:27:18
 Re: C mounted plow manual in reply to Stevie, 06-21-2002 23:46:44
Over on the left side of this page at the top you will find repro manuals for sale. Last I looked they had the manual you need but here are the basics. You should have a "U" shaped framework that fits in front of and in-between the final drives. There are two brackets that bolt on the final drives to attach the U frame. They need to be pointed down. The depth adjustment bell crank attaches under the brake pedals. You should have a length of flat iron with multible holes the goes from the bell crank to the U frame. The rockshaft is the part with two depth adjustment levers, It attaches behind and under the seat and the depth adjustment rod goes to the bell crank. With these parts installed, attaching the plow should now be obvious. I have a few pictures I can send but have no way to post them on this forum. E-mail me if you would like to see them.
