CA gears grinding?
Mike
06-21-2002 21:50:20
Just completed rewiring my CA with one wire alternator and 12 system, runs great.
However, when I tried to get in gear all gears just ground. I put in 3 gal of fluid a few months ago and it has all run in the floor. I put in two gal in the left fill point tonight and it did not help. It sounds like I need to add more fluid to the other side, if there is a plug there. Will low fluid cause the gears to grind and not mesh together?
Thanks for all of your help on this and the other tractor problems.
Mike
