Ca and b rims
mr.allis
06-20-2002 20:44:12
I want my ca to set nose down. Would a B allis front rims bolt up to my ca. My CA has 5.00-15, the B has ?.??-14 I think. Are the lug pattern the same or different?
Thanks for your help
Will
06-21-2002 12:19:52
 Re: ca and b rims in reply to mr.allis, 06-20-2002 20:44:12
The "B" should have 5:00-15 on it also,the "CA" rims should bolt right on the "B".
Kip Hansen
06-21-2002 13:47:06
 Re: Re: ca and b rims in reply to Will, 06-21-2002 12:19:52
Some Bs & Cs used 4.00-15s they are mounted on the same rim as your CA. You might also check the junk yard for small 15" temporary spare tires. A lot of small GM cars w\ 14" tires used a small 15" temp. spare that is a little smaller than a 4.00-15.
Will
06-21-2002 19:47:49
 Re: Re: Re: ca and b rims in reply to Kip Hansen, 06-21-2002 13:47:06
Yes Kip you are right about the 4:00-15, I had a brain Fart.
