Power Steering Failure on a D15
Mark Hall
06-20-2002 19:42:47
Ok, what generally fails on this system? pump? shaft? keyway etc? Thanks, need some help.
Mark
Dave Grubb
06-24-2002 09:16:37
 Re: Power Steering Failure on a D15 in reply to Mark Hall, 06-20-2002 19:42:47
Without more information on the failure we can't help too much. I have had a power steering failure that had no external leaks or noise or anything. It turned out to be a sheared key at the pump pulley/pump drive shaft. You can put a mark on the pulley and the pump shaft nut or whatever and run the tractor and operate the steering. Shut off the tractor and see if the marks are still matched or not. If not that maybe a pump failure.
Phil Auten (Tx)
06-24-2002 06:41:43
Mark,
On most power steering systems the seals fail causing a loss of the fluid. Tell us what your symptoms are and we can get more specific.
Phil
