WD45 Oil Lines
Steve Slaughter
06-20-2002 18:05:44
I've replaced the motor in my 1948 W Speed Patrol with an engine from a WD45 and I am transferring all the components to the new engine. (Water manifold, magneto, water pump, oil filter base, oil lines, etc.) The oil lines on the WC motor went from the filter base to a T-fitting low on the block, and from the T-fitting to an L-fitting in the cylinder head. But on this WD45 there seems to be an oil line fitting on top of the governor housing that was not on my older model WC engine. (I assume to lubricate the governor and timing gears) Can someone familiar with the WD45 confirm that this is an oil line fitting and how the lines are configured to supply oil to it. Is there an additional TEE in the lines? A picture would be helpful if someone has a manual that shows how the lines are routed. Thanks
Greg(Mo)
06-21-2002 06:45:31
 Re: WD45 Oil Lines in reply to Steve Slaughter, 06-20-2002 18:05:44
Yes, that is an oil line on top of the governor.
It gets fed right from the "T" fitting below the
dipstick.
Steve Slaughter
06-21-2002 07:39:27
 Re: Re: WD45 Oil Lines in reply to Greg(Mo), 06-21-2002 06:45:31
Thanks, Greg. Can you tell me where the line from the cylinder head goes, then? Mine goes from the T-fitting below the dipstick directly to the fitting in the head.
Greg(Mo)
06-21-2002 22:26:50
 Re: Re: Re: WD45 Oil Lines in reply to Steve Slaughter, 06-21-2002 07:39:27
did you get the sketch I sent you in email?
Steve Slaughter
06-22-2002 13:55:14
 Re: Re: Re: Re: WD45 Oil Lines in reply to Greg(Mo), 06-21-2002 22:26:50
Greg, I did get the sketch. Thanks for taking the time to help out. It was exactly what I needed. I still have to find an extra T-fitting. This morning I bought some 3/16" brake line and compression sleeves to make the additional oil line runs. Thanks again. Steve
Greg(Mo)
06-22-2002 20:50:29
 Re: Re: Re: Re: Re: WD45 Oil Lines in reply to Steve Slaughter, 06-22-2002 13:55:14
Glad I could help out. Any auto parts store should have the tee fitting...and I hope you meant 5/16"
line in your post (instead of 3/16") Have fun, those engines run good!
Greg(Mo)
06-23-2002 07:39:23
 Re: Re: Re: Re: Re: Re: WD45 Oil Lines in reply to Greg(Mo), 06-22-2002 20:50:29
Disregard that comment about 5/16 line....I must
have had a brain fart on that one. I thought it
was bigger tubing until I went out and looked again.
