Oil type for trans. and hand clutch
Harold Sisel
06-19-2002 21:20:06
I put in 80-90 hy presure tran oil but the hand clutch takes some time to stop slipping when cold
i was told to put in heavy duty 30 wieght oil
or no 821 john deere hydro oil and it will work fine
becouse the 80-90 is too heavey
any help on what oil you use in them will be helpful
as the 80ep that should be in there is not available
Thanks Harold
Brian G. NY
06-20-2002 20:02:14
 Re: oil type for trans. and hand clutch in reply to Harold Sisel, 06-19-2002 21:20:06
I use 80/90 in both my WD and WD-45. I agree that there is a bit of drag on the hand clutch when cold, but you also have to consider that the Tranny and Diff. are being lubed with this as well. I use modern hydraulic fluid in the hydraulic system in place of the old non-detergent 20W oil but I haven't taken that big step to using it in the Trans./Diff. yet.
DanD.
06-20-2002 11:25:41
They changed the recommendation from the 80EP even on newer D17's. I'd use trans-hydraulic oil that you can get almost anywhere..even Wal-Mart has it in 5 gallon pails. Alternatively, use AGCO power lube 821 XL.
