Re: D-14, bent push rods
Trent Williams
06-16-2002 17:07:58
You said the previous owner did head work. Does it look like anything else was done (cam, gears, ect..) If the head was the only thing removed, then the VALVE timming should be as it was. The valves should not be able to come close to the pistons. I don't think you could do anything to the IGNITION timming to cause this.
