Converting d-19 to negative ground
steve m
06-12-2002 13:39:10
I would like to convert my gas d-19 to negative ground in order to run some implements that require negative ground (round baler) electrical power. My tractor has the stock generator and regulator. I know that I have to reverse the wiring on the coil and the ampmeter. How do you repolarize the generator on a d-19?
DanD.
06-12-2002 19:07:25
 Re: converting d-19 to negative ground in reply to steve m, 06-12-2002 13:39:10
You would need a different voltage regulator, too. They are different for either positive or negative ground. Follow the instructions that come with a new regulator for polarization.
