D17 Diesel that stalls
Bruce Brockman
06-10-2002 19:03:22
Is it a dificult job to replace the brake shoes on a D17 ? Also does the entire trans need to be torn down to get to the cylinder ?
JMS/MN
06-12-2002 00:24:55
 Re: D17 Diesel that stalls in reply to Bruce Brockman, 06-10-2002 19:03:22
Depends what series it is. Early ones were band, like WD45, later were band/disc- need to pull the axle (Series three, maybe four?)
Craig MO
06-11-2002 17:10:32
You will have to pull axles out to get to the brakes. You will need a jack and preferably a hoist. I have done them by manhandling the axle housing but I'm getting smarter with age. You can axcess the three point cylinder by removing the three point cover on back. Be sure and replace the hose when you seal up cylinder.
