D-17 narrow front end problems
John
06-10-2002 04:26:46
I have a 1957 D-17 with a narrow front end. I would like to now if there is a way to remove some of the play in the front end? Did the d-17 of those years come with a three point hitch? If they did were can i get parts at?
I would like to restore this tractor and the slop in the front end is the one thing holding me back.
Thanks again
John
Gene[IN]
06-11-2002 17:41:55
 Re: D-17 narrow front end problems in reply to John, 06-10-2002 04:26:46
The D17 has a splined coupling inside the pedestal. This can wear and cause the slop. You will have to get an after market three point hitch.
JMS/MN
06-10-2002 22:52:00
Dont know about the D17. but my WD narrow front had problems, especially on hard surfaced roads- front wheels wobbled. Problem was a large bearing at the bottom of the spindle/ The rollers in the tapered bearing had cup-shaped wear, allowing the spindle to oscillate side to side.
Roy
06-10-2002 19:41:46
If you figure out the front end let me know because I am a D17 with the same problem.
