Forgot to check
Don Holden
06-09-2002 19:44:03
I took the D17 out of the shop this AM and started up the road. I looked back for traffic and alas I noticed a smokey haze trailing my little sweeheart. I stopped and discovered the Brake was still locked on!! She got real hot! I cooled her down and it appears there is still brake left but I will probably need to replace the shoes. Is this a big job? Are there any secrets that will make things easier for this old guy?
Thanks again, You guys are the greatest!!
Don
JMS/MN
06-10-2002 23:01:51
 Re: Forgot to check in reply to Don Holden, 06-09-2002 19:44:03
Which series D17? I think series one brakes were like the WD45- easy to replace bands. Series three had drum/disc combo, and requires pulling the axle to replace. Maybe you can adjust yours enough to work properly, without having to replace parts.
Don Holden
06-11-2002 11:23:46
 Re: Re: Forgot to check in reply to JMS/MN, 06-10-2002 23:01:51
JMS/MN, It is a series 2. The Serial Number is 33383! I took the cover off and gave it a quick inspection and it looks like there is still brakes left so maybe it is not as bad as I thought.
Thanks again for your reply.
Don
Tom
06-11-2002 18:33:29
 Re: Re: Re: Forgot to check in reply to Don Holden, 06-11-2002 11:23:46
Had this happen several times to the 45 I used to use on the farm where I worked as a kid. Had enough power you never noticed the brakes were on, till the smoke started. We always just took up the brakes if they needed it, once in a while replaceing them. Once a brake drum "blew up" Don't remember if it had to do with the brakes being on at the time, but probably being heated super hot a few times didn't help too much.
