Wd45 hydraulics
chucky
06-08-2002 08:18:48
how can i put hyd. cylinders on the bucket so i have down pressure? what do i do about the plumbing part of it? thanks for all replys !!
JMS/MN
06-10-2002 22:58:29
 Re: wd45 hydraulics in reply to chucky, 06-08-2002 08:18:48
If you want down pressure on your loader, you need to put two-way cylinders on the boom (lift arms) of the loader, not the bucket.
Tom
06-08-2002 18:37:12
You have at least two options: The first one is to add a two spool valve and connect in the system. This will allow you to operate the cylinders on the arms and the bucket. The tractor hydraulics are high pressure/low volume - which is really not compatible for loader operation. The second option is to add a pump on the front of the crank shaft. This will give you live hydraulics, all the volume you need and it leaves the tractor system for other uses that it was designed for. Kelley Manufacturing makes a good loader that bolts onto the '45 and will fix you up with a pump, valves, double acting cylinders, reservoir and etc. Their number is 219-255-4746 - ask for Tony. Best wishes!
