Bent-shaft or curved-shaft tractor umbrella?
Bryan Smith
06-07-2002 13:20:01
The website below sells both bent-shaft and curved-shaft unbrellas for tractors. Any of you have either of these? I think the curved-shaft allows you to rotate it and move it around. I'd like to know if anyone has had an experience with either style - pro or con. Thanks.
Leroy
06-10-2002 04:20:53
 Re: Bent-shaft or curved-shaft tractor umbrella? in reply to Bryan Smith, 06-07-2002 13:20:01
The straight shaft you set off to the side part out out side the cover, the curved shaft you set directly under the center, more shade all around you
BUTCH (NC)
06-08-2002 06:06:14
I INSTALLED A CURVED SHAFT ON MY MF 165 TUESDAY MOWED THE PASTURE WED TEMP GOT UP TO 95 MADE A BIG DIFFERANCE. WITH THE CURVED SHAFT YOU CAN LEVEL THE UMBRELLA EVEN IF SHAFT IS NOT MOUNTED PERFICLY STRAIGHT. PAID 65.00 AT AGRI- SUPPLY
Don C
06-07-2002 19:25:30
Used them as a boy on the farm ,back then we only had straight shaft .....seems like they would be more stable..... anything to get out of the hot sun..... .TRY tractor supply I saw them there.....
