WD45
ChrisB.
06-06-2002 17:41:18
Hello All,
I was wondering where I could find out more info on the WD45 models? What kind of options do they have? I am looking at buying one right now and I am not to sure what I should be looking for on the ACs!! What kind of implements would I be able to use on it? Could I brushhog with it and put a 3 point hitch on it?
Thanks,
Chris B.
GlennDinFL
06-07-2002 21:13:37
 Re: WD45 in reply to ChrisB., 06-06-2002 17:41:18
It'll pull a bushog without any problem. A 3 point conversion is not a problem and is easily done. Good luck if you decide to buy it. RegardS: Glenn
ChrisB.
06-07-2002 21:22:02
 Re: Re: WD45 in reply to GlennDinFL, 06-07-2002 21:13:37
Thanks Glenn for the info. But the ad says that it also comes with a tagalong, is that a trailer or what? Sorry about the stupid question but I am 17
Thanks,
Chris
David T (MO)
06-11-2002 06:50:10
 Re: Re: Re: WD45 in reply to ChrisB., 06-07-2002 21:22:02
A tagalong or tandom brushhog is trailer styled and pulled. Advantages are a smoother cut across rough pastures. Disadvantages are; can't lift it over stumps etc., sharp turns are hard on the PTO shaft, backing up is very difficult. My WD45 came with the tandom and after the first season I bought a 3pt to replace it.
