WD tow weight
Greg Anderson
06-04-2002 20:05:37
Does anyone know the approximate tow weight of an AC-WD? It has hydraulics and a bucket if that makes much difference. I've never seen it and will be towing it several hundred miles. It also has a brush hog mower, model/width unknown. Any information is greatly appreciated.
Thanks.
GlennD
06-07-2002 21:31:40
 Re: WD tow weight in reply to Greg Anderson, 06-04-2002 20:05:37
With the loader and bush hog, I'd estimate it at 5,000lbs, depending on how much has rotted away� Don't forget to figure the trailer weight as well.
James (MO)
06-05-2002 20:51:52
I'd recommending hauling it instead of towing. You will have to tow slowly and will wear out tires, maybe gears, bearings, etc - that just weren't meant to run at highway speeds. FWIW!
Greg
06-05-2002 20:33:39
My Operator's manual lists the WD shipping weight on rubber as 3975 lbs. You'll have to add the other equipment you have to get closer to your actual towing weight.
Jim (Mi)
06-05-2002 05:30:17
Just had mine weighed (48' WD) Sunday. Approx 8 gallons gas. Narrow front, unloaded 13.6 tires. With me on 195lbs===3620lbs.
JMS/MN
06-04-2002 21:01:16
WD45 weighs about 4600 pounds. Loader will add some additional, but not a great deal. WD is similar in weight.
Don C
06-06-2002 06:20:26
 Re: Re: WD tow weight in reply to JMS/MN, 06-04-2002 21:01:16
You are asking the total weight of this equipment.....so you will take the proper hauling equipment,to haul it home,---right? My guess is the total wt. would be around 5500# ....the tractor probably has water in the tires and weights .....can't tow it on the road very far ....recomended tow speed with tractor on the ground is 20 MPH max..... .
JMS/MN
06-06-2002 21:25:04
 Re: Re: Re: WD tow weight in reply to Don C , 06-06-2002 06:20:26
Good point on the tires having fluid in- towing distance is limited. I pulled (not trailered) one about 140 miles once, and the fluid caused a rear tire failure.
