Gear Ratio
Puller504
06-03-2002 23:57:39
I have aquired my brother-in-law's 1953 WD. Would like to know if anyone has knowledge of a slower ratio ring and pinion setup or who would manufacture one. The WD is geared too fast for the track. She runs fine, just needs a lower first gear speed. thanks for any info in advance!
Don C
06-08-2002 06:23:38
 Re: Gear Ratio in reply to Puller504, 06-03-2002 23:57:39
Don't know auything about pulling,,,,,but smaller diameter tires will give the same result..... do they make a low profile tractor tire ?
Nate
06-04-2002 19:49:44
I think the later WD's and WD 45 had a lower first gear, but you would have to swap the whole rear.
Donald J. Bihn
06-04-2002 14:15:23
Sorry, Will. I don't need more horsepower. The class I won with this tractor last summer only allows 35 horsepower on the dyno. My WD is right on the limit permitted in this class. Therefore I need to travel a little slower to avoid powering out. This 4500# class should be 45 horsepower, but then I would win it with my snortin' IH504, which I did before they dropped the HP limit. This group doesn't like giving prize money to out of county pullers. (They take our entry money tho)
Will
06-04-2002 08:25:30
I think that you should add more Power instead of tearing into the gears.
