Is it normal for an AC 180 to warm up very quickly?
J. Helton
06-02-2002 19:08:36
My 180 warms up to about the half-way point on the temp. gauge after just a few minutes. It then stays close to the red "hot" area. Is this normal?
DJ
06-09-2002 19:34:26
 Re: Is it normal for an AC 180 to warm up very quickly? in reply to J. Helton, 06-02-2002 19:08:36
You first need to find out if it actually getting hot. Put a thermometer in the radiator and then run it and conferm that it is hot.
Craig MO
06-03-2002 17:54:58
It sounds like the thermostatis sticking. I would replace it and the gasket. While you have the antifreeze out look down in the radiator and see if there is corosion in the tubes. If there is you will probably have to have radiator boiled and rodded.
Bryan Smith
06-03-2002 06:15:36
Sounds a little warm. Is your temp sending unit in good shape? Easy, fairly cheap replacement but that may not be the problem. Next step would be to check the radiator - blow out the fins with an air compressor and make sure there are no obstrutions. Make sure the fan is turning correctly and not slipping on the belt, and check the water pump. Then I guess you'd get into replacing the thermostat and/or boiling out the radiator.
Our 190XT and our neighbor's 200 run right at the start of the operating temp on the gauge and always have, even in 95+ degree days of harrowing or chisel plowing. You may be fine, but it won't hurt to check what you can.
