CA Hand Clutch Problems
Trevor
06-02-2002 06:06:50
We are restoring a CA and we just got our rebuit motor in it and had it running for the fist time, but the hand clutch does not work.
The tractor was in bad shape when we started and had been left outside for years. We know very little about Allis but are learning alot.
What is likely wrong with it? How hard is it to fix and how expensive are the parts? (By the way we are in Ontario Canada)
We have thought of not fixing it but that is kind of the key feature for a CA.
Thanks for your help
Max(ia)
06-02-2002 17:02:47
 Re: CA Hand Clutch Problems in reply to Trevor , 06-02-2002 06:06:50
I had almost $350 in parts. I had to replace with used parts, that means both axles, clutch assy and brake drum. The clutch facing and seals were new. Someone had bolted the clutch facings together, that held but the clutch housing had broken up. The brake drum had gotten into the drop housing, ruined the drum and ate out the keyway in the outer shaft. MY CLUTCH DIDN'T WORK EITHER lol. It's not to hard to work on if you have good tractor support and a way to handle the axle housing away from the tractor. Hope this helps Max
