Re: WD Transmission fluid/Hydraulic Oil
Author |
Gene {In]
06-01-2002 07:39:26
Pete, the hand clutch & hyd.pump are in the same compartment and use 20W or 10W non-foaming oil, depending on outside temperatures. If you want to change the final drive oil, remove the pan from the bottom. {90W gear lube] Also, the trans.& rear diff. use 90W gear lube.
Tom
06-01-2002 10:16:17
Re: Re: WD Transmission fluid/Hydraulic Oil in reply to Gene {In], 06-01-2002 07:39:26
I think you are mistaken. I think the hand clutch is the same oil as the transmission and rear end. The hydraulic pump draws from it's own sump, it does lube the belt pully though I think. The hydraulic oil is filled and checked with the little dipstick on the left side of the bellhousing casting. The transmission has two filler plugs on the left side.
Pete S
06-01-2002 20:13:39
Re: Re: Re: WD Transmission fluid/Hydraulic Oil in reply to Tom, 06-01-2002 10:16:17
I looked before I went to Fleet Farm for oil. My perticular tractor appears to get all of it's hydraulic oil from the tank mounted behind the gas tank. I didn't see a "pump" on the tranny but, I have a pump on the front of the engine. I purchased 80W-90 for the tranny and gears, and trans clutch areas. I looked and saw three drain plugs on the bottom as well a small plug on the PTO and the Draft adjust(?). I believe I know where to fill but how do you check the level to be correct. I bought 6 gallons of oil. Thanks! Pete S
Bryan Smith
06-03-2002 06:34:11
Re: Re: Re: Re: WD Transmission fluid/Hydraulic Oil in reply to Pete S, 06-01-2002 20:13:39
Sounds like your WD45 has an external hydraulic pump on the front of the engine to give it "live" hydraulics with a reservoir behind the gas tank. The WD45 still has an internal hydraulic pump to operate the 3 point hitch arms and remote cylinder coupling - it's checked by the dipstick noted and takes the 20w hydraulic fluid mentioned. Then you have the transmission which is filled through the plugs .... simple enough?? ;-) I have a few images of fill locations for the WD45 on my website under "oil capacities and oil type recommendations" - but none of them will show your external pump or reservior.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life.
... [Read Article]
Latest Ad:
2 old Dodge Pickup Trucks not running mostly complete early 50s flathead 6cyl stepside box side entry hoods Price 1200 both.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
