WD-45 misses
Weldon
05-31-2002 20:32:19
Runs smooth some times, other times 2 or 3 cyl will miss. When this occurs it will run ok for a period after restarting. New plugs, wires, distributor last year. What next?
howard
06-01-2002 17:23:54
 Re: WD-45 misses in reply to Weldon, 05-31-2002 20:32:19
how are your manifold gaskets?
Bryan Smith
06-03-2002 06:27:08
 Re: Re: WD-45 misses in reply to howard, 06-01-2002 17:23:54
Assuming it's a battery ignition set-up, have you replaced your coil? Or perhaps your condenser has gone bad already ... the intake manifold idea sounds like a good thing to check. Could (or could not) be a fuel flow problem if this occurs under load - maybe a sediment bowl, fuel inlet cleaning would help.
