Ac 200 ..lost reverse
keith
05-30-2002 19:24:36
just wondering if anyone with a 200,ever had this happen,gear shifter goes through the motions for reverse,but nothing there at all,maybe someone can tell where too start,all the fluids are o.k.,just driving across the yard and went to back up and nothin'.
thanks, keith
DJ
06-09-2002 19:41:24
 Re: ac 200 ..lost reverse in reply to keith, 05-30-2002 19:24:36
We never have any used reverse forks at our dealership, they are always sold to fix tractors like yours.
Craig MO
06-01-2002 19:00:54
There is a set screw in the shifting fork that can come out allowing fork not to move. You could have also broke the shifting fork. On 7000's which are similar to the 200's they had a habit of the pin that holds reverse idler gear would creep back into the rear end housing. If shifter goes through the motions pull floor plate out. Put transmission in second gear and pull shift cover to inspect. When reinstalling make sure reverse gear slot is lined up with slot on second gear.
Bryan Smith
05-31-2002 05:34:49
We had a similar problem with a 190XT, although it was like that when we bought it. Turned out to be a gearshift linkage adjustment for ours. I hope yours is as simple ....
