WD Transmission fluid
Jake (ME)
05-30-2002 15:34:32
What is the fluid in the transmission of a WD??
Jake
Gene [In]
05-31-2002 17:26:24
 Re: WD Transmission fluid in reply to Jake (ME), 05-30-2002 15:34:32
Don't use 90W in hyd.. use non-foaming 20W in hyd.
steve II
05-31-2002 08:01:29
80-90W (GL-5, EP) has been used in my (fifty-year old now!) WD for ten years with no problems. You will need close to five gallons (and a little patience) in order to top it off. Since the manual clutch and transaxle are separate, joined castings, Allis provides two filler plugs; both are beneath and behind the clutch pedal.
Bryan Smith
05-31-2002 11:26:22
 Re: Re: WD Transmission fluid in reply to steve II, 05-31-2002 08:01:29
I'm sure the 90w in the hydraulics works, but the higher viscosity would slow things down a bit as well as raise the hp requirement for the hydraulic pump, I think! Do you use external hydraulic cylinders much (harrows, etc.)? Just curious about how slowly they would raise.
Dave Grubb
05-31-2002 05:58:44
The transmission, rear end, and final drives get 80W gear oil. The hydraulic system gets any of the fluids the other guys mentioned.
steve
05-30-2002 19:51:37
50 years ago it was 20 wt engine oil. today most people prefer to use something like hy-trans, a hydraulic transmission fluid you can get at Farm Center or Wal Mart. It is a 20 wt hydraulic oil with anti foam and anti water dispersants.
Bryan Smith
05-31-2002 05:37:01
 Re: Re: WD Transmission fluid in reply to steve, 05-30-2002 19:51:37
Check out my website and look under tractor oil specs - I have a page there that lists the original oil reccommendation and the amount. Maybe that will help you get started.
