Hot Plugs for D 14
D 14 Dan
05-30-2002 11:59:06
What would be a good plug to buy for D-14? I want a good hot plug and I'm using autolite 85 in tractor now and would like a Hotter plug for better efficency. Thanks in advance for you input.
D 14 Dan
Bryan Smith
05-30-2002 13:11:48
 Re: Hot Plugs for D 14 in reply to D 14 Dan, 05-30-2002 11:59:06
Autolite 303 has been recommended for AC's with battery ignition systems in the past. Autolite 295 has been recommended for magneto systems.
Do you need the hotter plug to help prevent fouling from worn piston rings? If the tractor runs fine with the 295 or 303 plugs you won't need anything hotter.
