Allis B
Darrell G
05-30-2002 08:50:25
My Allis B Oil Pump stopped working and before
I noticed the oil pressure had went down the
engine started knocking. I cut it off before it
got to bad. The local tractor repair shop
quoted around $1,200 to replace bearings and
oil pump. Does anyone know if this is a decent
price. Should I just sell for parts?
Tks
Butch (OH)
05-30-2002 11:21:53
 Re: Allis B in reply to Darrell G, 05-30-2002 08:50:25
Terry R's figures come pretty close to my experience, but remembver he is doing his own work. $300 for the crank work and bearings, $300 for the pump (gosh that sounds high) = $600. Probably two days work. Shop rates around here are $40 per hour x 16 = $640. $1240 is real close to your guys estimate, he isn't doing you any favors, but he isn't taking you either. Only you can decide if you want to put that much in it. Working on a B engine is simplicity itself. If you have the tools and a place to do it you might give thought to doing it yourself.
Darrell G
05-30-2002 11:35:04
 Re: Re: Allis B in reply to Butch (OH), 05-30-2002 11:21:53
I appreciate everyones advice. I do have a place and some tools to work on engine. Dropped the Pan and looks like the tractor will have to be split to get to oil pump.
Thanks again for the advice.
Butch (OH)
05-31-2002 07:59:05
 Re: Re: Re: Allis B in reply to Darrell G, 05-30-2002 11:35:04
Darrel, get a shop manual if you don't have one either I&T or Allis. You will be lead through the whole proceedure.
Bryan Smith
05-30-2002 10:23:44
Thta may be an OK price considering the machining and labor - but you can buy a running B for $800 to $1400 depending on where you are and the condition of the tractor. You may want to consider buying another B and swapping the motors if your tractor is in good shape except for the engine - or the other tractor may be in better shape all around. Having a second one for parts doesn't hurt if you have somewhere to store it. You may also be able to buy just an engine for a good bit less than $1200. The later B and C both had the same CE engine, and the CA had it too with a higher governor rpm setting (1650 rpm instead of 1500). That gives you at least 3 models to find an engine from. Of course, if you fix the engine you'll know what you have.
Greg V.G.
06-02-2002 05:36:09
 Re: Re: Allis B in reply to Bryan Smith, 05-30-2002 10:23:44
I would like to know where to buy a (B) running for 800.00 to 1400.00 . There are none in Michigan . you can find a crappy one that needs tons of work starting at 1700.00
Bryan Smith
06-03-2002 05:20:46
 Re: Re: Re: Allis B in reply to Greg V.G., 06-02-2002 05:36:09
You just need to move south, Greg ...! The prices I mention are what we find in NC, SC, and Georgia. B's and C's are fairly common down here - about as common as WD/WD45's in the midwest. We had a nice running B sold at Godley's Auction in Charlotte NC recently for $700. Nice place to visit - they have an auction once a month and there are usually 50 to 100 tractors there, many of which are shipped in from the midwest. All makes and sizes. The last time I went there were only two AC's there, though - both B's.
Greg Ballantyne
06-02-2002 07:40:21
And I thought tractors were high in Md. I paid $1200 for a 49 B running good with belly mower. It was 9 years ago, though. But I don't think that price would be out of line today in this area.
Terry R.
05-30-2002 11:06:34
I just totally rebuilt my c engine.New sleeves,pistons,rings,bearings.I had it line bored so i didnt have to use the shims.I had the cam resurfaced.I resized the rods.New water pump.The only thing i didnt replace was the oil pump,which is sold new for 300.00 dollars.Also had crank ground.All that i had right under 1500.00 stuck into it.I have another c with a spun rod bearing.Should take and have the crank turned and rods resized.Figured about 300 to do it all.So i think 1200.00 for yours is high.Hope this helps,Terry.
