Will it pull it?
Brent
05-29-2002 12:26:52
Have a d-17 diesel and a minneapolis moline 4-26"disk I've been told it is a "breaking disk".
Bought it (disk) at scrapyard about to be cut up.
It is a drag type with three adjustable cast wheels-one front and two in back and weighs 2300 lbs. Your comments appreciated, especially if info on disk vintage,uses etc.
Craig MO
05-29-2002 18:54:30
 Re: will it pull it? in reply to Brent, 05-29-2002 12:26:52
We had a 3 bottom disc plow if thats what you are refering to and pulled it with Super M to clear stump ground and hardly knew it was back there. They pull easier than molboard plow. You should be ok.
Brent
05-30-2002 14:11:44
 Re: Re: will it pull it? in reply to Craig MO, 05-29-2002 18:54:30
Thanks for your info. Craig. Pardon my ignorance, but what hp is your superm?
Brent
Craig MO
05-30-2002 15:59:18
 Re: Re: Re: will it pull it? in reply to Brent, 05-30-2002 14:11:44
Its about 50 55 hp.
Brent
05-31-2002 09:34:21
 Re: Re: Re: Re: will it pull it? in reply to Craig MO, 05-30-2002 15:59:18
That's reassuring Craig. Thanks again.
