WD45 head or head gasket.?
dennis
05-26-2002 18:13:43
I started my WD45 today to use my bush hog. When it started on the first crank like always, I got a shower of antifreeze. There is nothing unusual about the oil color, but it is a half a quart low. Does this mean a blown gasket or maybe worse. The tractor starts and runs fine, plenty of power. I parked it until I can figure out what is wrong. Has anyone else had antifreeze fly out of the muffler on their WD45? I had the horse power checked recently on a pto machine. It checked at 38 H.P. That was the hardest this tractor has been run in years. Maybe that was the cause of this problem. Any help would be greatly appreciated. Dennis
Ron
05-26-2002 20:46:18
 Re: WD45 head or head gasket.? in reply to dennis, 05-26-2002 18:13:43
Try removing the sparkplugs, after it has set for a while..... then crank it over... You will see which cylinder is getting wet. I can't tell from what you have said, but I would certainly re-torque the head, just to see if that changes it any. It is not all that hard to pull that head off, for a new head gasket....Getting it to stop seaping may take some time, after you do, tho... Mine seaped for a month, before it sealed up...!! You may just want to re-torque, then use "Bars-leaks", and run it..... Good Stuff....
