CA HAS A KNOCK
DAVE
05-25-2002 19:05:58
I'VE BEEN WORKING ON MY DADS CA WHICH HASN'T RUN IN ABOUT 10 YEARS. WE PUT SOME PENETRATING OIL IN THE CYLINDERS AND CRANKED HER SLOWLY BY HAND FOR TWO WEEKS BEFORE TRYING TO START IT. THE OLD TRACTOR FIRED UP BUT SOUNDS LIKE SHE HAS A SMALL KNOCK AT IDLE. THE KNOCK SEEMS TO GO AWAY WHEN I INCREASE THE RPM'S. ANY IDEAS WHAT MIGHT BE THE PROBLEM?? OIL PROBLEM?? ENGINE PROBLEM??
DAVE
05-28-2002 23:34:35
 Re: CA HAS A KNOCK in reply to DAVE, 05-25-2002 19:05:58
Thanks for the tips. I was thinking valves or pushrods might be the trouble. Another thought, I have light oil in her in addition to the penetrating oil. I think I'm going to drain it out and put in some straight 30 weight oil. I think this might solve the problem.
Gene [In]
05-28-2002 16:47:50
Turn the p.t.o. off and see if that helps. Some times the hyd. pump will give you that sound at idle.
Donnie
05-27-2002 08:26:51
My B had a similar knock.Like yours the engine had not been run for several years.I found my pushrods to be bent.After learning prices to replace them I straightened them with a rubber hammer and an old piece of I-beam for an anvil.Iknow my tractor run fine when parked.I think maybe the rods bent somehow when I first turned the engine over,maybe stuck somewhat.I don't know if this will fix yours.Just something to consider.Good Luck.....Donnie
