AC/D-17
BUD SCHAEFER
05-23-2002 06:58:32
I HAVE BEEN TO A FEW FARM AUCTIONS AND FELL FOR THE 17'S.WOULD IT WORK FOR MOVING ROUND BALES A SHORT DISTANCE FOR SAY 50YDS ON FLAT GROUND WITH FRONT WEIGHTS.I AM NEW TO THIS TRACTOR STUFF NEVER HAD ONE BEEN TOLD BUY A FEW OLD BOYS THAT IT WAS A GREAT TRACTOR . DON'T NEED A FIELD TRACTOR JUST GOING TO DO A LITTLE DRY LOT WORK AND SOME ARENA WORK FOR HORSES MAYBE SOME LITE TILLING.AND WHAT IS A FAIR PRICE FOR ONE, NOT RICH.AND DOES SOMEONE KNOW WERE TO LOOK I LIVE IN ILL. OR IS THERE ANOTHER TRACTOR THAT WOULD WORK.I REALLY LIKE THE LOOKS OF THE D'S .WOULD THANK FOR INPUT----- ----- --THANKS BUD
Scott(MO)
05-26-2002 20:10:24
 Re: AC/D-17 in reply to BUD SCHAEFER, 05-23-2002 06:58:32
Bud, We used a D17 series IV for hauling out round bales to the cows and it worked great. Now we have a front end loader and haul 2 at a time , still works fine.
Scott
Bob Bartosch
05-25-2002 20:59:44
How do you identify the different series D-17s (1-4)?
Also, "Buda", is that an engine made by an outside manufacture, a special made by Allis, or the STD. for that tractor, and how do you identify it?
steve
05-26-2002 18:43:43
 Re: Re: AC/D-17 in reply to Bob Bartosch, 05-25-2002 20:59:44
BUDA was an emgine manufacturer that Allis Chalmers acquired. They made diesel engines. Most of the engines were used in the construction machinery division, but some of the big tractors and combines had diesels also. as for the series number, the serial number is on theleft rear corner of the engine to flywhell housing mount. you can get the serial number, then look up the series. I think the later 3-4 series had cream wheels in the front and the grill, not sure the first ones had that. main difference in the series was that the IV had live pto and hydraulics, exterior pump. what ever you get, make sure it has a three point hitch.
Craig MO
05-23-2002 18:14:25
Bud the D 17 will work great for you they will pick up a 1000# bale easily are easy to work on and super dependable . Prices from $2000 to $4500depending on condiyion and series.
BUD S.
05-24-2002 05:52:35
 Re: Re: AC/D-17 in reply to Craig MO, 05-23-2002 18:14:25
thanks Craig Mo for info.I just hope I can get one now.we have been unable to locate one for a while.But will keep looking.I just really liked the way the looked and it felt like the right size for me and work I wanted to do.thanks again.Bud
Roy
05-23-2002 15:29:51
Have a D17 with a 262 Buda engine. Its one heck of a puller!
BUD S.
05-24-2002 05:54:14
 Re: Re: AC/D-17 in reply to Roy, 05-23-2002 15:29:51
THANKS FOR INFO
steve
05-23-2002 15:27:09
a D17 is an excellent tractor, one of the best. they mad a series 1-2-3-4. of course the 4 is more in demand due to updates in the hydraulics, live PTO, etc. We had a series III, good tractor. Look for one with a three point hitch. They cost $500 to get one later. I would guess you can lift about 800 pounds with the 3 point, ours had about 200 pounds of weight under the radiator. You could probably lift a little more with more front end weight, but 800 is a good plan. A base tractor might start about $2000. If you get up to a series IV and in good shape, you might be about $3500-$4000.
BUD S.
05-24-2002 06:00:51
 Re: Re: AC/D-17 in reply to steve, 05-23-2002 15:27:09
THANKS FOR INFO I WILL BE LOOKING FOR SERIES 4 BUT WHERE WILL IT BE POSTED.I JUST HOPE I CAN FIND ANOTHER ONE.THEY SEEM TO GO SO FAST.THANKS AGAIN FOR YOUR HELP.I MAY NEED IT AGAIN SOME DAY.BUD
Roy
05-23-2002 15:25:09
