WD positive ground?
Jake
05-21-2002 15:28:53
I have a 1950 WD with the negative side of the battery hooked to the starter and a positive ground. Does anyone know why this is? The generator is not connected.
Jake
James (MO)
05-21-2002 18:14:42
 Re: WD positive ground? in reply to Jake, 05-21-2002 15:28:53
That's the way they came from the factory.
Bryan Smith
05-23-2002 13:46:33
 Re: Re: WD positive ground? in reply to James (MO), 05-21-2002 18:14:42
Waaay back when they thought current flowed in one direction, so everything was positive ground. Later they discovered it flowed in another direction - hence negative ground. At least that's one solution that has been offered ....!
All the older AC's - up through my 1963 D15 Series II at least (which by the way is 12 volt) - were positive ground. You can change it to negative ground if you like if you (a) polarize the generator, (b) reverse the leads on the ammeter, and (c) reverse the wires on the coil. No real reason to do this - 6 volt positive ground works fine.
