6 cylinder diesel forklift
tim busenitz
05-21-2002 11:56:48
We are trying to check the timing on a '65(aprox.)AC forklift. Does anyone know where to find a diagram of this engine, or know where the timing should be set? thanks! Tim
Craig MO
05-21-2002 21:10:40
 Re: 6 cylinder diesel forklift in reply to tim busenitz, 05-21-2002 11:56:48
If its got a 2800 or 2900 series motor the timing marks should be on the crankshaft pu;;ey. You will have to remove the small inspection window on the injection pump and line up th 2 marks. If you line up on the pulley and only have 1 mark in the pump window you are on no. 6 and need to turn the motor over to get on no.1.
