Mower belt keeps breaking
Kay
05-19-2002 10:22:02
we just replaced the mower belt on our lawn tractor and the new one shredded within 5 minutes
what should we look for that could be causing the problem?
it's a model 312 and the serial number is 15502615
Don
05-21-2002 09:13:34
 Re: mower belt keeps breaking in reply to Kay, 05-19-2002 10:22:02
All of the advice is very good....the most over looked problem is pulley design....most ocmpanys make there oun design.....use the dealers belt..
Keith G.
05-20-2002 06:54:36
Worn sheaves(pulleys)will cause belt to roll over and this will cause failure. seen belts roll 180 deg. they don't last long like this. Keith
Kent
05-20-2002 06:26:41
third party image
I agree with all the advice you've been given. Just wanted to point out that the site below may be valuable as you continue to use this fine piece of 30-year equipment....
Lh
05-19-2002 11:27:18
Check your bearings, rough spots on the pulleys, and alignment. With the belt off make sure all the pulleys turn freely by hand.
Sprinter
05-19-2002 17:26:27
 Re: Re: mower belt keeps breaking in reply to Lh, 05-19-2002 11:27:18
Also make sure you get a new belt from your local AGCO or Simplicity dealer. Parts store belts will not work on these mowers.
John S-B
05-21-2002 20:28:14
 Re: Re: Re: mower belt keeps breaking in reply to Sprinter, 05-19-2002 17:26:27
Neither will belts from TSC if they are not specific for that mower. The belt I bought for my craftsman mower only lasted a couple of weeks. I went to sears and got a OEM belt and have'nt had any problems.
Kay
05-24-2002 09:57:29
 Re: Re: Re: Re: mower belt keeps breaking in reply to John S-B, 05-21-2002 20:28:14
I don't know what a"OEM" belt is :(
Sprinter
05-24-2002 15:09:49
 Re: Re: Re: Re: Re: mower belt keeps breaking in reply to Kay, 05-24-2002 09:57:29
Kay,
An OEM belt is a belt from the "Original Equipment Manufacturer". Get your belts from AGCO or Simplicity. Simplicity built all of the Allis-Chalmers lawn tractors and their dealers can usually cross the model numbers over to Simplicity and get you the "right" belt.
Kent
05-24-2002 19:12:16
 Re: Re: Re: Re: Re: Re: mower belt keeps breaking in reply to Sprinter, 05-24-2002 15:09:49
third party image
No biggie, but Allis-Chalmers actually built the 300 and 400 series mowers in their plant in Lexington, South Carolina. They are an Allis-design and only the transmissions and rear-ends are made by Simplicity....
Allis also built the some of the 100-series and all the 200-series in the Lexington plant, but they were based on Simplicity designs and almost everything is interchangeable....
Kay
05-25-2002 09:40:45
 Re: Re: Re: Re: Re: Re: Re: mower belt keeps breaking in reply to Kent, 05-24-2002 19:12:16
thanks everyone as you can tell I'm not too knowledgeable about this-or it's a"blonde" thing :):)
my husband has retired the tractor to the garage for now
my next door neighbor came over and finished the lawn
hubby did fix the old Lawn Boy push mower but we have over half an acre and that's a lot to mow
