WD-45 Sediment Bowl Question
John in OK
05-18-2002 14:42:39
The Sediment bowl on our WD 45 has numerous washers under it as spacers so the bail will tighten up. So here's the big question, do I have the correct bail and bowl? The bowl OD is 1 7/8" and the height is 3/4". The bail is 3" tall. I measured these with the items on a flat surface, not on tractor. Where is a good place to buy a replacement gasket and bowl/bail if needed. Thanks
John in OK
James (MO)
05-18-2002 17:32:49
 Re: WD-45 Sediment Bowl Question in reply to John in OK, 05-18-2002 14:42:39
Someone has put a different bail on your sediment bowl assembly. You can make a gasket from neoprene or cork (available from a local auto parts store). The local TSC (Tractor Supply Company) store should have the entire sediment bowl assembly for about $25. I bought a new one for my WD. The old one kept leaking and the bail had several spacers between it and the glass bowl. FWIW!
