AC WC unsytled narrow Front horizontal axle
David
05-18-2002 08:49:48
Need information on how to get the front horizontal spindle off a narrow front unstyled WC.Any help would be greatly appreciated.
L Hud
05-18-2002 17:50:19
 Re: AC WC unsytled narrow Front horizontal axle in reply to David, 05-18-2002 08:49:48
To remove the spindles, you need to remove the bolt that is located on the bottom of the spindles.There are usually some shims located under the washer. Next remove the jam bolt on the front of the spindles. This holds the key that keeps them from turning . The next thing is to knock them off. Probably they will fall off. It is easier done if you remove one of the wheels.
Hope this helps.
L Hud
