Re: CA governor problem (1952)
SEAMO
05-17-2002 08:31:17
I was the one that suggested you test your tractor by locking up the brakes. I have never seen a governor that had all the weights and pins that didnt work some. Unless the sleeve or thrust brg is stuck. I am curious as to what happens when you open it wide open with the hand throttle? Does it go wild or does it do nothing?Post back in the same place so we dont have to hunt.
kent
05-17-2002 09:19:32
 Re: Re: CA governor problem (1952) in reply to SEAMO, 05-17-2002 08:31:17
i can't figure it out either. and the sleeve and thrust bearing aren't stuck. they're actually in good shape. when I move the hand throttle, the engine will rev up fine. you can get a pretty high rpm out of it and the arm on top of the governor does move when you move the hand throttle. thanks for your help.
