Zenith carburetor gasket
Bus Driver
05-14-2002 16:58:35
AC part number 223987, fuel bowl gasket for Zenith carburetor 212845 (this gasket fits several Zenith models). This carburetor is for a 1950 B. Is this gasket available as a separate item? It really is the only part that I need at the moment. Will buy more than one if necessary to make order minimum. Any suggestions for a source? Thanks for your help.
Steve in N.J.
05-17-2002 07:23:49
 Re: Zenith carburetor gasket in reply to Bus Driver, 05-14-2002 16:58:35
Mike,
It's in the mail!..... .....Steve
Steve in N.J.
05-15-2002 08:28:43
Hey Bus Driver,
Found a bowl gasket for ya if yer' interested. Can mail it out to ya if you want it. All it'll cost me is 34 cents....mere tupins to bail out a fellow Orange associate! Drop me a line....
Steve B.
Phil Auten (Tx)
05-15-2002 07:46:07
Bus Driver,
Get a sheet of gasket material from the auto parts store and make your own. Simply cut it out with a sharp knife or single edge razor blade (carefully). Shouldn't be very difficult. In a pinch, I've even used an old phone book cover.
Phil
Steve in N.J.
05-14-2002 20:00:32
Bus,
I've only ever purchased the carb kits. I've got a 48 B. Not sure if they are available seperately. Maybe possibly Agco would have them seperate. I rebuilt my carb, and wound up rebuilding another for a friend of mine. Same Zenith carb # 212845. His is a 50 B. Got the kit from Napa/Echlin. Even on automobile carb gaskets I've never seen the carb body gaskets available seperately other than the base gasket and possibly an accelerator pump gasket...I have a few broken carb kits at the shop. Might be able to find a bowl gasket for ya.. Steve
