Wc starting
Keith
05-11-2002 03:56:20
I am trying to find a way to get a 1937 WC to start with an electric starter instead of the hand crank. Does anybody know of a way to do this that looks decent? Can I take the bellhousing and other parts off of a later model WC and make that work somehow?
Thanks,
Keith
john
05-14-2002 06:00:32
 Re: wc starting in reply to Keith, 05-11-2002 03:56:20
keith yes you can and i got the stuff to do it with bellhouseing to starter all that in between if you need it
Joe M
05-11-2002 04:33:15
I believe you will need the bell housing, starter, starter rod and you may need to check your flywheel, many early tractors with no electric start didn't have teeth on the flywheel.
Other than a little sweat, shouldn't be too hard.
All you will see after you are done will be the starter itself and the battery and box.
